Add/Remove Vertices on a Polygon
Vertices can be added or removed from polygons by using the plus (+) and minus (-) keys on your Number Keypad.
Prepare Polygon Vertices for Addition/Removal
Ensure the polygon to be edited is displayed on the map.
In the Map Manager tool, select the polygon group and right-click to select Edit Vector Group. A shaded frame will appear around the polygon on the map.
Click the left mouse button on a polygon edge in the map and then click the right mouse button and select Edit Vertices. The Map Polygon Edit Toolbar is now activated from where you can add/remove polygon vertices.
Add additional vertices on a polygon:
Place your cursor, between two vertices on the polygon, where you want to place the new vertices. Press and hold the + key on your Number Keypad (note that, a plus sign (
) is added to your cursor).
While holding down the + key, use your mouse to select the location for the new vertices.
Remove vertices from a polygon:
Place your cursor on the vertices you want removed. Press and hold the - key on your Number Keypad (note that, a minus sign (
- While holding down the - key, use your mouse to select the vertices to be removed.
