Summary of Oasis montaj Files
As you work with the system, you will become familiar with a variety of standard files used for specific functions. The following list provides a summary of the more important files.
File Type |
Geosoft File Extension |
Geosoft Database |
Geosoft Grid |
Colour information for grids/images |
Geosoft eXecutable |
Geosoft Script |
Geosoft projection information |
Geosoft Map (used in the MapInfo software to distinguish a Geosoft map file from a MapInfo (*.map) file |
The following provides detailed lists of the key files in Oasis montaj. This information can be useful for both project archiving and keeping track of files created in the system during processing and map preparation steps.
Data Files
File Type |
Extension |
Description |
ASCII |
*.XYZ |
Raw text file containing location (random or line) information and data values. |
Blocked Binary |
*.RMS |
Raw binary file containing location information and data values. Format consists of fixed block binary records. For more details see the IMPORTBB GX topic. |
Geosoft Database |
*.GDB |
Object-oriented database that stores Earth Science data in a form that delivers fast access to data and efficient storage required for applications that deal with very large volumes of data. |
Geosoft Binary |
*.GBN |
Geosoft-developed open-format binary file. |
Import/Export Files
Grid and Image Files
Map Files
Plot Files
File Type |
Extension |
Description |
AutoCAD |
*.DXF |
External plot format typically used to depict surficial or buried object extents or surfaces, as well as cultural elements, such as building outlines or roads. |
Plot |
*.PLT |
Binary file that integrates basemap and layer information. |
Plot Attribute |
*.ATT |
Binary files containing graphics element attribute information.
Processing Files
File Type |
Extension |
Description |
Batch |
*.BAT |
ASCII file containing DOS commands required to execute a sequence of actions. |
Control |
*.CON |
ASCII file containing default or custom parameters that control a program's operation. |
Script |
*.GS |
ASCII file containing default or custom parameters that control one or more Geosoft eXecutable operations on a Geosoft database. |
System Files
Resource Files
