Create Your Own Custom Menus
If you find that you use specific GXs more often than others or that you have a specific set of GXs that you run in sequence, you may want to add them to your own custom menus. This can be accomplished by creating Oasis montaj menu files.
A menu file is simply an ASCII text file with the *.omn or *.smn extension containing the menus and submenus that run specific Geosoft eXecutables (GXs), GX.Net procedures, and dependencies attached to a specified menu. There are a variety of menus available including:
- the main menu system in Oasis montaj, coremenus_main.omn.
- sub-menus, e.g. map_tools.smn.
- specific application menus such as magmap.omn or euler3d.omn.
Normally, a menu consists of a menu name, items, separators, and submenus. The elements in a menu are summarized in the table below:
Create a Menu File
- The best way to see how this is done is to copy and edit one of the OMN files shipped with Oasis montaj.
- Store your custom menu files (OMN, SMN) in your user menu folder: %USERPROFILE%\Documents\Geosoft\Desktop Applications\omn.
- Use the Project > Manage Menus option to add your custom menu(s) to the main toolbar in your Oasis montaj project.
Expand to see a fragment from a typical OMN file (geophysics_levelling.omn)
If you are missing a GX, GS or a product, click here for technical support and resources.
