Import ArcGIS LYRX File
Use the Import ArcGIS LYRX File option (geogxnet.dll(Geosoft.GX.ArcGIS.ImportLYRX;Run))* to add an ArcGIS Pro Layer File (.lyrx) to a new or existing 2D map or 3D view. When added to a new map, the extents of the Data view are defined by the extents of the data referenced by the layer ("LYRX") file.
The option is available under the following menus:
Map > Import > ArcGIS LYRX File
ArcGIS Tools > Import ArcGIS LYRX File
This functionality can only be accessed on systems that have a licensed copy of ArcGIS Pro installed.
Import ArcGIS Pro LYRX File dialog options (Map)
Import ArcGIS Pro LYRX File dialog options (3D View)
Supported Types
Feature class: in order to import a LYRX file created from a feature class, you must have both the LYRX file and the ESRI file geodatabase (to which both the feature class and the LYRX file are associated).
Shapefile: a shapefile is essentially a feature class that is not linked to a file geodatabase. To import a LYRX file created from a shapefile, you will need the shapefile and the LYRX file.
ArcGIS Map Service: a map service is a data hosting service that provides map images for display in a client application, and the images can be rendered dynamically for a specific extent or pre-rendered and cached in a tile grid as static images. To import a LYRX file created from a map sevice, you will need only the LYRX file.
Supported Versions
LYRX files generated in the following ArcGIS Pro versions are compatible for import into Oasis montaj: 2.8, 2.9, 3.0, 3.1, and 3.2.
Currently, Oasis montaj does not support the import of files that have been created in ArcGIS Pro versions 3.3 & up.
Reprojection
The projection of the LYRX files is honoured in Oasis montaj:
When the imported LYRX file is added to a new map, the coordinate system of the map will be automatically set to the coordinate system of the first LYRX file added to the map.
A LYRX file that is not natively in the coordinate system of the current map, is re-projected “on-the-fly” to the coordinate system of the map.
You can always check the status bar of the map window for information on the map's coordinate system and units.
Geosoft Map Identify Tool
LYRX files serve as visual representations of live data links, and you can use the
ArcGIS Pro Style Files (.stylx)
You can search for styles in ArcGIS Online, use the styles that are authored by Esri and included in the ArcGIS Pro installation. or you can create your own style file (.stylx) in ArcGIS Pro.
To save a style, you just need to create a style in a project, select a file location for the style file (the location can be on a file system outside your ArcGIS project), and populate it with symbols or other style items. You can then share this .stylx file the same way you share any other file.
