Import ASEG-ESF
Use the Database > Import > ASEG-ESF menu option (geogxnet.dll(Geosoft.GX.Database.ImportAsegEsf;Run)*) to import ASEG-ESF data into the current or a new database.
Import ASEG-ESF dialog options
ASEG-ESF file |
Specify the name of the ASEG-ESF file to import. This file contains a header defining the data type and a body. The header defines the mandatory fields. Each row of the body represents a specific sample, and each column represents a particular data field for that sample. Script Parameter: ASEGESF.FILE |
Output database |
Specify the Output database name. It defaults to the same name as the input ASEG-ESF file. Script Parameter: ASEGESF.DATABASE |
The ASEG-ESF format intends to cover all Electrical methods data formats. It is an ASCII fixed field flat file that contains a header and a body. The header fully describes the type of survey.
The description of the ASEG-ESF file format can be found here:
