Merge Sorties into Survey Database
Use the Merge Sorties into Survey Database option (geogxnet.dll(Geosoft.GX.UAVSurvey.MergeSortieIntoSingleDatabase;Run)*) to collate all the survey segments of data that line up into a single line. The merged line(s) will be saved to an output database; you can then proceed with filtering and interpreting your merged database.
The option is available from the following menus:
- UAV Merge Sorties > Merge Planned Sortie
- UAV Merge Sorties > Merge Sortie without a Plan
Merge Sorties into Survey Database dialog options
Survey name |
Select the survey you would like to work with from the list of available project surveys. Multiple surveys can be created within the same GPF. Script Parameter: PLAN_UAV_SURVEY.SURVEY_NAME |
If a set of planned subareas covering the AoI is available, the field Select subarea will become available. If, however, there is no planned survey available, you will be asked to select databases to merge instead.
Channel to level |
Select the data channel to level into the survey database. Script Parameter: LAN_UAV_SURVEY.DATA_CHANNEL |
Output survey database |
Specify a name for the output survey database that will contain your merged survey areas or split databases covering the entire AoI. Script Parameter: PLAN_UAV_SURVEY.OUTPUT_SURVEY_DATABASE |
The average difference in the overlapping section of two adjacent lines from two sorties is applied to the data segment on the right as a DC shift to reduce it to the level of the segment on the left. The overlapping sections are tapered prior to merging the two.
The GX does not cross-level flight and tie lines. It will also report on repeats and dummies encountered throughout the merge.
Merging can be performed in any order, so that segments of any part of a line merge into the growing output merged line.
A report file as <Surveyname>_<Sortie>_MergeReport.txt is generated to report the merged lines as well as any warnings and/ or errors.
Expand to see the workflow steps in merging sortie databases into the final database:
Finds all the lines in the supplied databases (*.gdb) with the same line number and potentially different versions.
Starts with the line closest to the origin (i.e., for lines in the NS directions, it finds the line with the lowest Y value; for lines in the EW directions, it finds the line with the lowest X value).
Flips lines as necessary, so that all are travelling in the same direction.
Finds the overlap with the next lowest line segment with the same line number.
Determines the average difference in the area of overlap, DC shifts the second segment by that value, and merges it with the first one.
Continues until all lines with the same line number are processed.
Moves to the next line number and repeats the process.
Saves the complete merged line into the output database.
