Voxel to GOCAD
Use the Voxel > Conversions > Voxel to GOCAD menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ExportVoxToGocad;Run)*) to export a Geosoft Voxel to a GOCAD Voxet.
Voxel to GOCAD Voxet dialog options
Voxel file
Select the Geosoft voxel file to export.
Script Parameter: EXPORTVOXTOGOCAD.INPUT_VOXEL
GOCAD Voxet file
Specify the name of the GOCAD Voxet file to create.
Script Parameter: EXPORTVOXTOGOCAD.GOCAD_VOXET_FILE
Orientation
Select the orientation of the Z axis of the GOCAD file:
  • ZPOSITIVE Elevation
  • ZPOSITIVE Depth
See the Application Notes below for GOCAD and Oasis montaj conventions and standards.
Script Parameter: EXPORTVOXTOGOCAD.ORIENTATION
In GOCAD, the standard is Z-positive down (depth), whereas in Oasis montaj, the convention is Z-positive up (elevation). In the dialog, you may specify either a 'standard' or an 'inverted' orientation, where 'standard' follows the Geosoft’s convention, and 'inverted' follows GOCAD's standard, as shown in the table below:
Option
Description
ZPOSITIVE Elevation
ZPOSITIVE Depth
ZPOSITIVE Elevation ( Z First)
ZPOSITIVE Depth (Z First)
Standard
Inverted
Standard (Z first)
Inverted (Z first)
GOCAD Format Limitation
Only Geosoft voxels with uniform values can be exported.
