GOCAD to Voxel
Use the Voxel > Conversions > GOCAD to Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ImportGocadToVox;Run)*), to import GOCAD Voxet files to a Geosoft voxel.
The import only supports GOCAD files in IEEE float format with property data in an external file.
GOCAD to Voxel dialog options
GOCAD Voxet file
Browse to select the GOCAD Voxet file to import.
Script Parameter: IMPORTGOCADTOVOX.GOCAD_VOXET_FILE
Output voxel
Specify the name of the Geosoft voxel file to be generated (.geosoft_voxel).
Script Parameter: IMPORTGOCADTOVOX.OUTPUT_FILE
Property to import
Select a property from the GOCAD Voxet file to import.
Script Parameter: IMPORTGOCADTOVOX.PROPERTY
Coordinate System
Coordinate System
The Coordinate System dialog allows you to specify the correct coordinate system information (Datum and Projection Method) for the input GOCAD Voxet file.
Script Parameters:
  • IMPORTGOCADTOVOX.IPJ_NAME
  • IMPORTGOCADTOVOX.IPJ_DATUM
  • IMPORTGOCADTOVOX.IPJ_METHOD
  • IMPORTGOCADTOVOX.IPJ_UNITS
  • IMPORTGOCADTOVOX.IPJ_LOCALDATUM
If a 3D Viewer is open during the import, the output voxel will be displayed in that 3D view. Otherwise, it will be displayed in a new Voxel Viewer window.
If the output voxel does not display, open the Advanced Settings dialog (Project > Settings > Advanced) and, under the Voxel Settings node, check if the Display Created Voxels option is set to "True".
