Grid Sections
Use the Grid Section(s) option to produce grids from a database array channel, correctly oriented in three dimensions.
ClosedExpand to see the two GX.Net variants for this option and the locations (menus) where this option is available.
geogxnet.dll(Geosoft.GX.GridUtils.GridArrayData;Run)*:
  • Section Tools > Grid Section(s)
  • 3D View >  Grid Array Data
geogxnet.dll(Geosoft.GX.GridUtils.GridArrayData;RunFrom3D)*:
  • 3D Viewer: Add to 3D > Grids >  Grid Sections
Grid Section(s) dialog options
Grid
Select the lines to grid; available options:
  • All lines: All the lines will be processed.
  • Displayed line: Only the currently displayed line will be gridded.
  • Selected lines: All selected lines will be gridded (default option).
See the Application Notes below for further details.
Script Parameter: GRIDCDI.LINES [ "A" : All lines, "S" : Selected lines (default), "D" : Displayed line]
Data array
Select the channel containing the data array to grid.
The list is populated only with the array channels.
Script Parameter: GRIDCDI.DATA
Depth array
If the depth increments are loaded onto the data array channel, this entry will be disabled. Otherwise, you can enter the depth array channel specifying the vertical location of each of the data elements to plot.
The entry is populated only with channels of the same dimension as the data array.
Script Parameter: CDI.DEPTH_ARRAY_CHAN
Negative depths
Check this option if the values in the depth array are specified in the same direction as elevation and decrease downward.
Script Parameter: CDI.NEGATIVE_DEPTHS_DOWN [0: unchecked (default), 1: checked]
Elevation
Use this channel to define topography or a reference elevation. If defined, the depth or relative elevation values are added to these values to give the true elevation ("Z") of each data value.
Script Parameter: CDI.ELEVATION_CHAN
Prefix of section(s)
Specify a prefix for the output section grids. Adding a prefix to your output grids may help you to filter (or sort) your sections. By default, this field is left blank, and no prefix is added to the output section grids.
Each grid section name is concatenated using the optional prefix, the channel name, the line name, and the selected display gridding method.
Script Parameter: GRIDCDI.PREFIX
Display option
Select from one of the available options:
  • Display grid: The output section grids will open in individual grid windows within the current project's workspace.
  • Do not display: The output section grids will be added to the current project and listed in the Project Explorer, but they will not open in the project's workspace.
    The option overrides the Advanced Settings parameter "Display Created Grids" when its value is set to "True".
  • 3D view: This option becomes available and is selected by default when a 3D view is open in the current workspace and is the active window. The output section grids will be added to the current 3D view and rendered in the viewer window.
This parameter:
  • Is disabled when the Run in background option is selected and re-enabled when Run in background is deselected.
  • Is not available when the Grid Section(s) dialog is opened from the 3D Viewer Add to 3D > Grids >  Grid Sections menu. In this case, the grids are automatically added to the current 3D view and displayed in the viewer window.
  • Is not available if a crooked section grid is displayed in the active window or is the current view in a section map.
Script Parameter: GRIDCOPY.DISPLAY_OPTION ["Do not display" (default), "Display grid", "3D view"]
[Run in background]
Gridding can be a resource-intensive task. The duration can range from minutes to hours, depending on the size of the dataset. By choosing the Run in background option, you can execute the gridding process asynchronously, allowing you to continue using Oasis montaj for other tasks while the gridding is underway. Multiple instances of the gridding process can run concurrently in the background, whether they are for the same database or different ones.
When you press the OK button with the Run in background option checked:
An Oasis montaj command-line window (OMS) will open and run in the background on the taskbar until the gridding task is complete. Oasis montaj becomes available immediately after the OMS console window is launched. Do not close the console window before the process finishes — this will cancel the gridding, and no output grid files will be produced. When the gridding process is complete, the console window will close automatically.
In the current Oasis montaj project, in the Project Explorer:
  • You can monitor the progress of your gridding while working on other tasks.
    The progress of the gridding is monitored, and the status (e.g., processing, completed, failed, cancelled) is visually indicated in the Jobs tab. A new node is appended to the tab, and entries for each of the output files are created under this node in the tree.
  • As the gridding process for each selected line in the database completes, the output section grid is automatically added to the Grids node in the Data tab.
    You can double-click on the job node in the Jobs tab to initiate a rerun of the gridding using the previously set parameters. You also have the option to adjust these parameters before starting the process again.
Closing the project (or the Oasis montaj instance) while background gridding is in progress will display a confirmation prompt. If you choose to close the project while the oms.exe is running in the background, the process will continue to execute to completion.
The selection state of the Run in background option is retained on subsequent runs of the gridding tool in the same project.
More
Select this button to reveal the parameters under the Display and Grid sections.
Display
The tab is not available when either the Run in background option is selected or the Display option is set to "Do not display".
Colour method
Specify the colour zoning method for rendering colour distributions. Select one of the options below:
  • As last displayed: the grid is displayed in its last viewed state: its previous colour transform is used, and the currently selected colour scheme will be ignored.
  • Default: the default colour distribution method is used.
  • Histogram equalization: your data values are evaluated, and the zones are statistically determined, such that data is equally divided among the histogram bins.
  • Normal distribution: your data is assumed to be normally distributed, and the zones are determined based on the standard distribution for a standard bell curve.
  • Linear: the range of data values are divided linearly into even increments.
  • Log-Linear: the zone values are updated based on the log distribution of the data, and the data is displayed using the log-linear colour distribution.
Script Parameter: GRIDCDI.METHOD [0 : Default, 1: Linear, 2 : Normal distribution, 3 : Histogram equalization, 5 : Log-Linear, 6 : As last displayed]
Colours
Select the colours for rendering the image of the grids. To modify the selection, click on the Colours scheme, and the Select Colour Scheme dialog will appear. Use this dialog to navigate through the scheme categories and to select a colour scheme to best display your grid(s).
Script Parameter: GRIDCDI.TABLE
Brightness
Specify the brightness of the grid image. The normal brightness is defined at 0. You can change the Brightness value from -100 (black) to 100 (white) using either the slider bar or by entering an exact value.
Script Parameter: GRIDCDI.BRIGHTNESS
Reverse colour distribution
Check the Reverse colour distribution option to reverse the distribution of the selected colour scheme.
For example, the colour scheme used for displaying resistivity data is the inverse of the scheme used for conductivity data. By enabling you to reverse the colour scheme on the fly, the same table can be used to display both.
Script Parameter: GRIDCDI.REVERSED [0: unchecked (default), 1: checked]
Pixel view
Select the Pixel view option for display purposes. By default, the grid is first interpolated to a smooth image at the screen resolution. If you prefer to honour the grid resolution, the image will appear pixelated, and the colour will change at the actual grid interval rather than the screen resolution. Formerly, this functionality was found under the image filters as " No smoothing (GRD)". Check this box to forgo the smoothing.
Script Parameter: GRIDCDI.PIXEL [0: unchecked (default), 1: checked]
Vertical exaggeration
Specify a single vertical exaggeration for displaying all the output section grids.
Press the calculator button (), located next to this field, to have the vertical exaggeration calculated. (It will be based on the longest section grid; see the Application Notes below for further details.)
If this parameter is not specified, no vertical exaggeration will be preset in the grid(s), and you will be prompted to provide one every time you open any of the generated section grids.
Script Parameter: GRIDCDI.VERTICAL_EXAGGERATION
Grid
Display method
Select a display method from the drop-down list. The selection includes three gridding methods and a pixel plot option:
  • Minimum curvature gridding
  • Inverse distance weighting
  • Direct gridding
  • Pixel plot
The Pixel plot option produces a grid-like output with a rectangle drawn around each data point. Unlike gridding, this preserves both the original location and data values. The pixel plot must be displayed on a section map (a pixel plot vector group will be added to the section view) or in a 3D view (an isosurface group will be added to the 3D Objects group). A prompt to open a map will appear if there is no current map.
With maps, there could be undesirable results if the section does not match the data view on the map, or if there are several sections created (e.g., "All" or "Selected lines" options). Either choose to display in a 3D view (each section will be displayed as pixel plots) or use the Create Section(s) from Data tool to create multiple sections on a map.
This option is not available when:
  • Run in background is selected.
  • Display option is set to "Do not display".
Script Parameter: GRIDCDI.DISPLAY_METHOD
Horizontal cell size
Vertical cell size
Depending on the Display method selected, it is possible to set:
  • Both the vertical and horizontal cell size for Inverse distance weighted gridding and Direct gridding.
  • Just the horizontal cell size: Minimum curvature gridding uses square grid cells.
  • Neither: Pixel plot cell sizes vary in both dimensions depending on the data separations.
Script Parameter: GRIDCDI.CELLSIZE_X
Script Parameter: GRIDCDI.CELLSIZE_Z
[Advanced Gridding Options]
Select the Advanced Gridding Options button to modify the parameters of the selected gridding method. For more information on the contextual parameters, click the Help button on the Advanced Gridding Options dialog.
For details on crooked sections, see the topic Crooked Section Grids.
When displaying a 2D view of the sections, for each selected line in the database, the following procedure is used to construct a grid file:
  • The section horizontal axis values are constructed using the accumulated distance calculated from these channels.
  • The section vertical values are taken directly from the Depth channel or property.
  • The azimuth of the grid is calculated based on the first and last (X,Y) locations in the line.
  • The geolocated linking is in effect, and the cursor location is properly tracked between 2D and 3D maps, and databases.
  • The grid is created using either the minimum curvature method, inverse distance weighting, or direct gridding. In addition, the pixel plot produces a grid-like output, but draws a rectangle around each data point, and so, unlike gridding, preserves both the original location and data values.
  • The name of the grid is constructed with the specified prefix, followed by the channel name (data array), line name, and the acronym of the gridding method used.
Calculate the Vertical Exaggeration for the Output Section Grids
When you click the calculator button (), the vertical exaggeration is calculated as per below:
  • For each selected database line, the data extents are used to calculate the section's aspect ratio.
  • A vertical exaggeration (VE) is calculated so that the longest section will be displayed at 2:1 aspect ratio.
The algorithm to calculate the VE from the longest section is:
defaultExaggeration = Math.Round(0.5 * width / height, 3);
This will cause the longest section to be displayed with a 2:1 aspect ratio. If its natural aspect ratio is 2:1, the calculated VE will be 1. All of the other sections will display with a smaller aspect ratio (smaller width at the same height).
You will not be able to see or change the vertical exaggeration that is set in the section grid(s). To specify a different value, run the GX again.
