Array Profile Plotting
In the database window, use the right-click menu option Array Profile Plotting (VAPLOT GX) to generate a plot of an individual array profile from an array channel in the current database.
This GX must be run interactively.
Plot Individual Array Profile dialog options
Title
Enter the title to be displayed at the top of the figure.
X Axis Annotation
Provide the annotation for the X-axis, shown at the bottom of the figure.
Y Axis Annotation
Provide the annotation for the Y-axis, shown on the right of the figure.
Profile width (mm)
Specify the width of the figure in millimetres.
Profile height (mm)
Specify the height of the figure in millimetres.
Profile colour
Select the colour to be used for the figure.
  • The Y-axis will be labelled using decimal values as defined in the data channel.
    To adjust the number of decimals shown, modify the decimal precision in the channel definition.
  • A new map will be created to hold the figure, named:
    "database_line_fidnum.map".
  • If a map with this name already exists, you will be prompted to confirm whether to overwrite it.
    To avoid overwriting:
    • Enter a different map name in the dialog, or
    • Rename the existing map using Map > Save As… from the map window.
