Array Section Colours
In the database window, use the right-click menu option Array Section Colours (VASCTCOL GX) to specify a colour zone file for rendering an Array channel within each database cell.
Set Section Colours for an Array Channel dialog options
Array channel
Select the array channel to be displayed.
Script Parameter: VASCTCOL.CHAN
Colour table
Select the colour scheme used to render the colour zone file:
  • Hovering over a colour scheme entry displays a tooltip with the name of the colour table and its folder.
  • To change the selection, click the colour entry and browse through the available scheme categories.
Script Parameter: VASCTCOL.FILE
The selected colour scheme file will be applied to display the array channel in each database cell when the section display option is enabled (see Array Profile/Section Options).
If the selected file is not a colour zone file, colours will be assigned using a Linear distribution.
