Butterworth Bandpass (BTWRB)
Use the Butterworth Bandpass option to apply a Butterworth bandpass filter.
Butterworth Bandpass Filter dialog options
Long wavelength cutoff |
Long-wavelength central cutoff, in ground units. |
Short wavelength cutoff |
Short-wavelength central cutoff, in ground units. |
Filter order |
Controls the sharpness of the filter at the cutoff wavelengths. The default is 8. |
The Butterworth bandpass filter passes the desired mid-wavenumber range while attenuating the low and high extremes of the wavenumber spectrum. The Filter order controls the degree of the sharpness of the cutoff wavenumbers:
Higher values make the filter shape closer to an ideal bandpass operator.
However, an ideal bandpass filter is not recommended because it produces ringing artifacts (Gibbs’ Phenomenon).
A common—but more complex—alternative is the Cosine Bandpass roll-off filter (FFTCOSNB).
Where:
k0 |
Low wavenumber cutoff (cycles per ground unit). |
k1 |
High wavenumber cutoff (cycles per ground unit). |
n |
Positive integer determining the sharpness of the cutoff. |
Wavenumber Domain Variable Definitions
The following variables are used in the wavenumber domain: |
k |
Wavenumber increment, used to depict a radially symmetrical variable. |
Where: np: number of points cs: cell size |
μ |
X-component of the wavenumber. |
v |
Y-component of the wavenumber. |
r |
Radial component of the wavenumber. |
θ |
Angular (polar) component of the wavenumber. |
Ground unit refers to the survey ground units defined in your grid (e.g., metres or feet). Ground units may be left undefined.
