Collar Data - Drillhole Import Wizard
Summary
Use this tab to specify the import parameters for the collar data to be imported into the current geodatabase feature dataset. Once all the required fields are specified and mapped, the message “Ready to import Collar data” will display at the bottom of the tab and the OK button will be enabled.
Drillhole Import Wizard - Collar Tab |
| Parameter | Explanation | |
Collar View |
The name of selected Collar data. Not editable. |
Database Fields |
The database fields that are available for import. Select (highlight) a field to specify the Channel Type and parameters. |
Filter Conditions |
Click this button to open the Filter Conditions dialog. |
| Channel Type | ||
Not imported |
Select the Not imported option if you do not want the selected (highlighted) database field to be imported. | |
Data |
Select the Data option if you want the selected (highlighted) database field to be imported as data. |
Hole ID |
Select the Hole ID option if you want the selected (highlighted) database field to be imported as Hole IDs. This is a required field. |
Easting |
Select the Easting option if you want the selected (highlighted) database field to be imported as easting survey data. This is a required field. |
Northing |
Select the Northing option if you want the selected (highlighted) database field to be imported as northing survey data. This is a required field. |
Elevation |
Select the Elevation option if you want the selected (highlighted) database field to be imported as elevation. This is a required field. |
Hole Top |
Select the Hole Top option if you want the selected (highlighted) database field to be imported as hole top data. |
Total Depth (EOH) |
Select the Total Depth (EOH) option if you want the selected (highlighted) database field to be imported as total depth data. This is a required field. |
Collar Dip |
Select the Collar Dip option if you want the selected (highlighted) database field to be imported as collar dip data. |
Collar Azimuth |
Select the Collar Azimuth option if you want the selected (highlighted) database field to be imported as collar azimuth data. |
| Parameters | ||
Field name |
Specify the field name. This field is read-only for required field types. |
Data type |
Specify the data type. This field is read-only for required field types. |
Data format |
Specify the data format. This field is read-only for required field types. |
Dummy |
Specify the alpha and /or numeric characters to be used as the dummy. The default is (*). |
Related Topics
Drillhole Import Wizard:
Import Drillholes from Excel or Access Files
Import Drillholes from an ODBC Connection
