From-To Data - Drillhole Import Wizard
Summary
Use this tab to specify the import parameters for the Interval (from-to) data to be imported into the current geodatabase feature dataset. Once all the required fields are specified and mapped, the message “Ready to import <From-To View> data” will display at the bottom of the tab and the OK button will be enabled.
Drillhole Import Wizard - From-To Tab |
| Parameter | Explanation |
From-To View |
The name of the selected Interval (from-to) data. This field is read-only. Additional sub-tabs are created for each selected Interval (from-to) data to be imported.
Database Fields |
The database fields that are available for import. Select (highlight) a field to specify the Channel Type and parameters. |
Filter Conditions |
Click this button to open the Filter Conditions dialog. |
| Channel Type | |
Not imported |
Select the Not imported option if you do not want the selected (highlighted) database field to be imported. |
Data |
Select the Data option if you want the selected (highlighted) database field to be imported as data. |
Hole ID |
Select the Hole ID option if you want the selected (highlighted) database field to be imported as Hole IDs. This is a required field. |
Depth From |
Select the Depth From option if you want the selected (highlighted) database field to be imported as "depth from" data. This is a required field. |
Depth To |
Select the Depth To option if you want the selected (highlighted) database field to be imported as "depth to" data. This is a required field. |
Assay |
Select the Assay option if you want the selected (highlighted) database field to be imported as assay data. |
Sample |
Select the Sample option if you want the selected (highlighted) database field to be imported as sample data. |
Standard |
Select the Standard option if you want the selected (highlighted) database field to be imported as standard data. |
Duplicate |
Select the Duplicate option if you want the selected (highlighted) database field to be imported as duplicate data. |
| Parameters | |
Field name |
Specify the field name. This field is read-only for required field types. |
Data type |
Specify the data type. This field is read-only for required field types. |
Data format |
Specify the data format. This field is read-only for required field types. |
Dummy |
Specify the alpha and /or numeric characters to be used as the dummy. The default is (*). |
Related Topics
Drillhole Import Wizard:
Import Drillholes from Excel or Access Files
Import Drillholes from an ODBC Connection
