Edit Internal Metadata
Use the Edit Internal Metadata option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaEditMetadata;Run)*) to edit metadata saved into UX-Analyze databases. This is primarily for legacy systems; see the Application Notes for more details.
UX-Analyze extension:
- AGC Dynamic Data > Utilities
- AGC Static Data > Utilities
- AGC Expert User > Utilities
Edit Internal Metadata dialog options
Database prefix | Select the prefix for the databases that need to be updated. All databases with this prefix will be updated. Script Parameter: UXA_MDE.PREFIX |
Database name | Enter the database that needs to be updated. Script Parameter: UXA_MDE.GDB |
Metadata Parameters | |
Survey mode | Select the survey mode from the list. Available options are Static and Dynamic. Script Parameter: UXA_MDE.SURVEYMODE |
Sensor / Configuration | Select the advanced sensor name from the list of available sensors. The list is populated from the SensorTableAdvanced.xml file located in the C:\Program Files\Geosoft\Desktop Applications \etc folder. Script Parameter: UXA_MDE.SENSOR_CONFIGURATION |
The internal metadata is set when importing data for the legacy systems and provides the link to the sensor table.
With the legacy systems, the raw (CSV) data file contains only positioning and transient data. The additional information required to describe sensor configuration is read from the sensor table. For the newer systems that use the HDF format for the raw data file, this is disabled and will display "Defined from data".
