Drilling Data
Drilling data forms the basis for creating models in Leapfrog Works. Import drilling data by right-clicking on the Borehole Data folder and selecting one of the import options:
Each of these options is discussed in the Importing Drilling Data topic.
Because drilling data often contains errors that reduce the reliability of a model, Leapfrog Works has tools that help you to identify and correct errors and work with the data. These tools are described in the Identifying and Correcting Data Errors in Leapfrog Works topic.
Once imported and corrected, drilling data usually requires further processing before any models are built. Leapfrog Works has a number of tools for processing drilling data; some of these options add new columns to existing tables and some create new tables.
Options that add new columns to existing tables are:
- Selecting Intervals. If the lithologies in a column are poorly sorted, you can display the column in the scene and use the interval selection tool to work with all the segments and sort them into new units.
- Splitting Lithologies. With the split lithologies tool, you can create new lithologies from lithologies in an existing lithology column by selecting from intervals displayed in the scene.
- Grouping Lithologies. The group lithologies tool lets you define a new unit to which existing units are added. For example, a sandstone deposit might appear in an interval table as poorly-sorted and well-sorted units. The group lithologies tool lets you group both units into a single sandstone unit.
- Overlaid Lithology Column. You may have two versions of an interval column, one that contains draft data and one that contains the final version. The final version may contain gaps, which can be filled in using the draft version. The overlaid lithology tool lets you combine the two columns to create a new column.
- Category Column From Numeric Data. When you have numeric data you wish to use with the lithology and category modelling tools, you can convert the numeric data to a category column.
Evaluated Columns. An evaluated column adds data to a table from another source within the project, often integrating some information generated from your analysis activities back onto some source data tables (back-flagging).
- Majority Category From Other Table. When you have category data such as economic compositing status or lithology data from another table, you can back-flag it onto an interval table.
Options that create new tables are:
- Category Composites. Sometimes unit boundaries are poorly defined, with fragments of other lithologies within the lithology of interest. This can result in very small segments near the edges of the lithology of interest. Modelling the fine detail is not always necessary, and so compositing can be used to smooth these boundaries.
- Majority Composites. Category data can be composited into interval lengths from another table or into fixed interval lengths. The compositing is based on a majority percentage where each interval is assigned a category based on the category that makes up the highest percentage of the new interval.
- Numeric Composites. Compositing numeric data takes unevenly-spaced drilling data and turns it into regularly-spaced data, which is then interpolated. Numeric data can be composited along the entire borehole or in selected regions. You can also set the compositing length from the base interval table.
- Back-Flagging Drilling Data. Evaluating geological models on boreholes creates a new lithology table containing the lithologies from the selected model.
- Merging Drilling Data Tables. If you are working with columns in different interval tables in the same drilling dataset, you can create a new merged table that includes columns from these different tables. Columns created in Leapfrog Works can be included in a merged table.
Finally, when you have data across multiple drilling datasets that you wish to use elsewhere in the project, you can create a combined drilling dataset that contains interval values, downhole points, downhole structural data and screens data from other drilling datasets. See Combining Drilling Datasets.
The rest of this topic discusses:
- How Drilling Data is Organised in Leapfrog Works
- Viewing Drilling Data Table Statistics
- Exporting Drilling Data
- Exporting Borehole Traces
See the separate Displaying Drilling Data topic for information on the different ways of displaying drilling data in the scene.
In Leapfrog Works, drilling data is organised into drilling datasets, which are made up of a collar file, a survey file and at least one interval table. A drilling dataset can also contain:
- Downhole points
- LAS points
- Downhole planar structural data
Here, a single drilling dataset made up of a number of tables has been added to the project, stored in the Borehole Data folder:
Here there are three drilling datasets, M Campaign, MAC Campaign and MV Campaign:
You can open each table () in a drilling dataset by double-clicking on it. The table will be displayed and you can make changes in it, as described in the Working with Data Tables topic. When there are errors in the data, the relevant table will be marked with a red exclamation mark (
). See Correcting Data Errors in Leapfrog Works for more information on fixing drilling data errors.
In addition to the imported tables, each drilling dataset has two objects that help in visualising and analysing the data. These are:
- The traces object. See Displaying Borehole Traces.
- The graphs object. See Displaying Borehole Graphs.
Individual drilling data tables can be deleted. However, the collar table is referred to by all other tables in a drilling dataset and so deleting the collar table will also delete those dependent tables.
To view statistics on an interval table, right-click on the table in the project tree and select Statistics. The following options are available:
Right-click on a numeric column and select Statistics to open a univariate graph for that column.
Changes made to the drilling data in Leapfrog Works only affect the Leapfrog Works database, not the original data files. You can export Leapfrog Works drilling data, which is useful if you wish to keep a copy of drilling data outside the project.
You can:
- Export all data in a drilling dataset. See Exporting All Drilling Data.
- Export all data in a drilling dataset in IFC format. See Exporting Drilling Data in IFC Format.
- Export only a single data table. See Exporting a Single Drilling Data Table.
These export options export the drilling data tables using To and From values to indicate location information. If you wish to export data with X-Y-Z values, extract points data using one of the following options:
- Extracting Contact Points from Drilling Data
- Extracting Intrusion Values from Drilling Data
- Extracting Interval Midpoints from Drilling Data
Then export the data object as described in Exporting Points Data.
If you need to export information on the geometry of boreholes without including the drilling data tables, you can export the borehole traces as a polyline. See Exporting Borehole Traces.
To export all drilling data in a drilling dataset, right-click on the dataset and select Export. The Export Borehole Data window will appear:
You can select whether the exported files includes all rows, only changed rows or only valid rows. You can also apply a query filter, if any have been defined for the drilling dataset.
Once you have selected how you wish to export the data, click OK. The Export Borehole Data Files window will appear:
The list shows the files that will be created, one for each data table. Choose the Folder where the files will be saved, then enter a Base file name, which will be added to the front of each file name. However, a Base file name is not required.
Drilling data can be exported in the following IFC formats:
- IFC 2x3 (*.ifc)
- IFC 4.0 (*.ifc)
- IFC 4X3 RC4 (*.ifc)
Drilling data can also be exported in IFC format via the bulk exporter. See the Exporting Project Data to IFC topic for more information.
To export a drilling dataset in one of the IFC formats, right-click on the dataset and select Export > Export to IFC. In the window that appears, select the objects you wish to include, then enter a filename.
When an object has more than one colouring option available, you must choose which one you wish to use. If there is more than one colouring option, the other options will be exported as attributes. In this example, different columns are selected when drilling data is exported and the IFC structure is shown in BIMvision. Note that the selected column is exported as a SolidStratum type (in IFC 4X3 RC4) and both columns are included as attributes:
You can also:
- Combine outputs into an archive, in ifczip format
- Change the units used to export the data:
- Length can be in metres or feet
- Plane angle can be in radians or decimal degrees
See the Exporting Project Data to IFC topic for more information on the differences between the supported IFC formats.
To export a single drilling data table from a drilling dataset, right-click on that table and select Export. The Export Borehole Data window will appear:
You can select whether the exported file includes all rows, only changed rows or only valid rows. You can also apply a query filter, if any have been defined for the drilling dataset.
Once you have selected how you wish to export the data, click OK. You will be prompted for a filename and location.
If you need to export information on the geometry of boreholes without including the drilling data tables, you can export the borehole traces as a polyline. Formats supported are:
- Drawing Interchange Polyline Files (*.dxf)
To export borehole traces as a polyline, right-click on the traces object in the project tree and select Export As Polyline. In the window that appears, you can choose which boreholes to include:
- None. All boreholes in the drilling dataset will be included.
- Selection. Choose from the list of boreholes in the drilling dataset.
- Query filter. Choose one of the query filters that has been defined for the drilling dataset.
Navigate to where you want to save the file, then click Save.
