Block Models
You can create the following types of block models in Leapfrog Geo:
  • Regular block models. A regular block model has blocks that are all the same size and are never divided.
  • Octree sub-blocked models. An octree sub-blocked model has blocks that are repeatedly divided into eight sub-blocks where selected triggering surfaces intersect the blocks. Instead of dividing a block entirely into small sub-blocks when sub-blocking is triggered, the block is first divided in half in a particular direction, and then only the partitioned blocks that still trigger a further division are divided into smaller units. This creates a series of sub-blocks of different sizes, and because many are larger than the smallest sub-block and the smallest sub-blocks only exist where a contact requires it, processing can be more efficient.
  • Fully sub-blocked models. With fully sub-blocked models, blocks are fully sub-divided when they contain a triggering boundary. This can create many sub-blocks and so processing a fully sub-blocked model can be slower than processing an octree sub-blocked model. In contrast to octree sub-blocked models, however, fully sub-blocked models support block subdivisions using numbers other than power-of-two numbers. Fully sub-blocked models do not support variable height sub-blocks.
  • Variable Z sub-blocked models. Variable Z sub-blocked models are fully sub-blocked in X and Y, but in Z the size of the sub-blocks varies to exactly follow triggering boundaries.
Fully sub-blocked models and variable Z sub-blocked models were introduced in Leapfrog Geo 2023.1. Sub-blocked models from earlier versions of Leapfrog Geo will be upgraded as follows:
  • A sub-blocked model that has the Variable height setting enabled will be opened in Leapfrog Geo 2023.1 and later as a variable Z sub-blocked model.
  • A sub-blocked model that does not have the Variable height setting enabled will be opened in Leapfrog Geo 2023.1 and later as a fully sub-blocked model.
Fully sub-blocked models do not support using open meshes as triggers. For this reason, when a sub-blocked model is upgraded to a fully sub-blocked model, any open mesh used as a trigger will be removed from the block model and Leapfrog Geo will display a message after the upgrade. Click on the View objects in Project Tree link to highlight objects that may have changed, and enable the option for saving a list of changes:
You will then be prompted to save a text file on your local hard drive. Open this file to see identify any meshes that have been removed from the block model:
The saved list of changes opened in Notepad, naming the mesh trigger removed by the upgrade.
Grouped meshes can be used as triggers and if you want to use an open mesh as a trigger, first add it to a grouped mesh.
You can also:
  • Regularise octree sub-blocked models, fully sub-blocked models and variable-z sub-blocked models into a block model that is not sub-blocked. Regular block models can be regularised into a block model with larger block dimensions and fewer blocks. See the Regularising Block Models topic.
  • Export block models. See the Exporting Block Models topic.
  • Import block models in different formats. See the Importing Block Models topic.
Geological models, interpolants and combined models can be evaluated on block models both created in Leapfrog Geo and imported into Leapfrog Geo. If you have the Leapfrog Edge extension, estimators can also be evaluated on block models.
The rest of this topic describes:
Creating New Block Models
To create a new block model, right-click on the Block Models folder and select New Block Model. In the window that appears, select the type of block model you wish to create:
Choosing the type of block model to create in the New Block Model window.
For more information on each block model type, see the following separate topics:
Block Model Volume Filters
Mesh volumes can be assigned to block models as volume filters. Right-click on a block model in the project tree and select New Volume Filter. Select the volume from the list of available objects.
Choosing a mesh in the Select Volume window when adding a volume filter to a block model.
Volume filters will appear as selectable options in the shape list properties panel’s Query filter, where the volume filter can be selected to show only the parts of the block model within the selected volume.
Displaying a Block Model
A thick slice of a block model, where blocks whose centroids fall outside the slice leave apparent holes.
The same block model in 2D slice mode, where every block that intersects the slicer is depicted.
The Fill slicer option provides the choice between an outlined shape for the intersection of each block with the slicer, or a filled shape.
The Show text option provides the choice between seeing a value on screen for each block intersecting the slicer, or not. The default value is the value for the column selected to colour the block model.
See Formatting Text Displayed in the 3D Scene for more information on how to use the text formatting dialog.
Block models can also be added to a section layout, where they will have an appearance similar to the 2D slice mode view. This presentation option includes a query filter and an index filter. See the Section Layout Editor topic for more information on designing section layouts.
When a block model is displayed in the scene, there is a Query Filter option that includes filters created in Calculations and Filters.
The Query filters list will also contain volume filters. To set a volume filter on a block model, see Block Model Volume Filters.
Choosing a filter from the Query filter list for a block model displayed in the scene.
  • If a category column is chosen, a Select Categories button can be used to select the discrete categories to show.
  • If a value column is chosen, a value range filter is shown.
  • If a date column is chosen, a date range filter is shown.
Using Select Categories to choose which categories are shown when the Display filter is set to a category column.
For more information on how to use the Display filter, see the Using the Display Filter section in the Filtering Data in the 3D Scene topic.
The Index Filter options for a block model, set to Subset with X, Y and Z range sliders.
  • Subset shows the union of the selected X, Y and Z ranges.
  • Sliced shows the intersection of the selected X, Y and Z ranges.
The X, Y and Z ranges each use a range slider.
A range slider in coarse control mode, shown dark blue with its handles at each end covering the full range of 1 to 160
The same range slider with its handles dragged in to restrict the range to 1 to 50
Dragging the selected section of a range slider to move the displayed range along, here to 52 to 101
Double-clicking a range slider switches to fine control, expanding the selected range of 52 to 101 across the whole slider
In fine control mode, moving the handles inwards further restricts the range from 52 to 101 down to 60 to 80
Right-clicking a range slider returns it to coarse control, restoring the earlier range of 52 to 101
Choosing a statistics type for a block model: Table of Statistics, Scatter Plot, Q-Q Plot or Box Plot.
The Table of Statistics option is described in more detail below. See the Saved Statistics topic for more information on the other options.
Right-clicking on a block model evaluation or a numeric calculation and selecting Statistics opens a univariate graph for the selection. See the Univariate Graphs topic for more information.
Table of Statistics
A table of statistics for a block model, with the rows organised by the category data columns.
The Query filter option uses a related filter to constrain the dataset to a selected subset.
The Hide empty categories and Hide inactive rows options below the Categories list.
Group by category and Group by numeric column provide options for the table organisation. You can also change what columns are displayed in the table by clicking the Edit columns button (). This opens a window in which you can select the columns that are displayed in the table:
The Edit Columns window, where each column can be shown or hidden in the table of statistics.
Click rows to select them, and select multiple rows by holding down the Shift or Ctrl key while clicking rows. You can then copy rows by clicking the Copy button (), which allows you to copy the selected row(s) or all rows in the table.
The arrow buttons quickly expand () or collapse () rows.
The Variance section of a block model evaluation's Properties window, giving the variance between and within blocks.
