SEG-Y Output Files (2D)
Use the Output Files dialog to convert the input 2D SEG-Y profile to Geosoft section grids and/or database. Specify which output type(s) you wish to generate and specify the names of the output files you wish to create.
Output Files dialog options
If a section grid is generated, it will be displayed in the current 3D View if one is open. It will also be displayed in a section grid viewer.
For more details on crooked sections, see the topic Crooked Section Grids.
If a database is generated, it will be displayed in the workspace. The database file will contain a channel for each trace-header field that contains non-zero data, as well as an array channel for the trace data. The sampling (Z-coordinate information) for the trace data is stored in the Array Base Properties.
