Butterworth Notch (BTWRN)
Use the Butterworth Notch option to apply a butterworth notch filter.
Butterworth Notch Filter dialog options
Wavelength cutoff |
Central Wavelength to reject, in ground units. |
Filter order |
Degree n of the sharpness of the filter operator (default = 8.0). |
The Butterworth Notch filter allows to reject the desired mid-wavenumber range while maintaining the low and high extremes of the wavenumber continuum. The Filter Order controls the degree of the sharpness of the cutoff wavenumbers.
Where:
kc |
Wavenumber cutoff in cycles/ ground unit. |
n |
Positive integer value determining the degree of sharpness of the cutoff. |
Wavenumber domain variable definition
k |
u |
v |
r |
θ |
also
