Notch (NOTCH)
Use the Notch option to apply the notch filter.
Notch Filter dialog options
Central wavelength |
Central wavelength to reject, in ground units. |
Power factor |
The larger the power the wider the rejected band. (Default=1). |
Depth factor |
The smaller the depth factor, the more abrupt the rejection band (default = 2). |
The Notch filter allows to reject the desired mid-wavenumber range while maintaining the low and high extremes of the wavenumber continuum. The Power controls how wide the rejection bad is; the Depth factor controls the degree of the abruptness of the wave form operator.
Notch Filter
Where:
k0 |
Cutoff wavenumber in cycles/ ground unit. |
n |
Power of the filter function |
q |
Degree of the filter function |
Wavenumber domain variable definition
k |
u |
v |
r |
θ |
also
