Shift Correction
Use the Shift Correction menu option (LVSHIFT GX) to create a level shift correction channel from an error difference channel. The correction is calculated as the average of the level errors (differences) at each crossing.
Create a Level Shift Correction Channel dialog options
Level error channel
The channel that contains the error data at the line crossings. This channel is normally created by loading the corrections from a correction table using the XLEVEL GX.
Script Parameter: LVSHIFT.ERROR
Output correction channel
The name of a new channel that will be created to hold the calculated shift correction. The corrections will be constant within a line.
Script Parameter: LVSHIFT.OUT
Maximum error
The maximum allowable error to use in calculating the correction. The errors will be clipped (+/-) this value before the correction is calculated.
Script Parameter: LVSHIFT.MAX
Process line types
"Selected" to process selected lines. "Tie" to process tie lines. "Lines" to process normal lines.
Script Parameter: LVSHIFT.TYPE
Use this GX to calculate average shifts that can be applied to lines minimize leveling errors. The resulting correction channel can be subtracted from the unleveled data using the LVCORR GX.
