The Math Expression Builder
The Math Expression Builder is an easy-to-use tool designed for working with mathematical expressions. It features a standardized interface that consolidates all math expression functions into a single, tabbed dialog box and is applicable to data within channels, grids, and voxels. Use this tool to create, save, load, and execute mathematical expressions efficiently.
The dialog provides direct access to commonly used parameters, operators, and symbols. The available Operators tabs vary depending on the data format—for example, Channel, Grid, or Voxel.
More Information
- Common operators and symbols: Common Keys
- Tool parameters and usage details: Math Expression Builder Components
- Table manipulation functions—findrow and tablelookup—which can read from CSV files and are not included in the Math Expression Builder Operators tabs: Table Look-up Expressions
