Statistics Tab
The Statistics tab offers fundamental statistical operators for working with numerical data in channels.
Each tab item includes a tooltip that shows the required arguments and a brief description of the function.
Statistics Operators
Button
Syntax
Definition
Operate on line |
selected (default)
current (_cur): is appended to the selected operator
all(_all): is appended to the selected operator
Your selection determines whether statistical properties are calculated on the selected lines, the current line, or all lines.The properties listed below are calculated on the line(s) selected.
The Operate on line option is available only in the Channel Math tool. It is not available in Grid Math or Voxel Math.
.min
Minimum value of the data
.max
Maximum value of the data
.mean
Mean (average) of values
.range
Range of the data
.count
Number of valid (non-dummy) data items
.stddev
Standard deviation
.stderr
Standard error
.variance
Variance of data
.countzero
Number of values equal to 0
.countdum
Number of dummy values
.sum
Sum of all values
.sum2
Sum of all squared values
.geomean
Geometric mean (only positive values)
.minpos
Minimum positive value
.countpos
Count of positive values
.sum3
Sum of all cubed values
.sum4
Sum of all 4th-power values
Statistical properties can be calculated on the current line, selected lines, or all lines in the database. Once calculated, these properties can be used in expressions. For example:
To subtract the mean of the current line from all selected lines, use:
C1=C0-C0_curr.mean
To instead subtract the overall mean (calculated across all lines in the database), use:
C1=C0-C0_all.mean
The Add Variable @ operator is not supported by the Statistics dot (.) functions.
Array elements (e.g., C1[1] ) are supported with the Statistics dot (.) functions.
