Import KMZ or KML File(s)
Use the Map > Import > KMZ or KML File(s) menu option (geogxnet.dll(Geosoft.GX.Map.ImportKMZorKML;Run)*) to import the vector elements (points, lines, polygons) of a KMZ or KML file into an Oasis montaj map.
The option is also available with the UAV Merge Sorties extension under the UAV Merge Sorties > Plan Survey menu.
Import KMZ or KML File(s) dialog options
KMZ or KML file |
Select the *.kmz or *.kml file to import. See the Application Notes below for more information on the format of the import file. Script Parameter: KMZ_OR_KML.KMZ_OR_KML_FILE |
Display |
Use the drop-down list to specify how to import the KMZ or KML file:
See Application Notes below for details on projection. Script Parameter: KMZ_OR_KML.DISPLAY [ 0 : Current map, 1 : New map] |
Keyhole Markup Language Format
KML (Keyhole Markup Language) is a file format used to display geographic data in an Earth browser such as Google Earth. KML files are used by many popular survey software and navigation systems. They are often distributed in KMZ files, which are zipped KML files with a .kmz extension. A KMZ file stores map locations viewable in Google Earth and contains placemarks that may include a custom name and the latitudinal and longitudinal coordinates of the location.
Rasters are currently not supported.
More information on the KML file format can be found at:
Projection
KML files, by specification, use a single projection: WGS 84 (ESPG 4326). All compatible vector data (i.e. points, lines, polygons) will be displayed on the (new or existing) map. When the imported data is added to a new map, the projection will be set to WSG 84. When added to an existing map, the data is reprojected "on the fly" to the coordinate system of the map.
