Special Tab
Use the Special tab to access a range of specialized functions used in mathematical expressions.
Each tab item includes a tooltip that shows the required arguments and a brief description of the function.
Special Tab options
Button |
Syntax |
Definition |
Math Functions |
min(,) |
Returns the minimum value of two channels for each row. |
max(,) |
Returns the maximum value of two channels for each row. |
div(,) |
Performs integer division of two channels per row.
sign(,) |
Transfers the sign of the fist argument to the second. Examples: SIGN(-1,10) = -10
SIGN(-1,-10) = -10
SIGN(1,10) = 10
SIGN(1,-10) = 10
ceil() |
Returns the next highest whole value of the specified channel. |
floor() |
Returns the next lowest whole value of the specified channel. |
abs() |
Returns the absolute value of the specified channel. |
round() |
Rounds the value of the specified channel to the nearest whole value. |
Data Functions |
window(,,) |
The leftmost argument is a channel, while arguments 2 & 3 define the minimum and maximum of a range. Values outside the defined range (min, max) are set to DUMMY. |
clip(,,) |
The leftmost argument is a channel, while arguments 2 & 3 define the minimum and maximum of a range. Values outside the range are replaced with the nearest boundary value (min or max). |
Miscellaneous |
randbetween (,) |
Generates random numbers between the specified minimum and maximum values. To create a new channel and populate it with random values, you must indicate the channel used to derive fiducial information (start & increment). This is done by specifying the base channel at the end of the equation after the semicolon: C0=ranbetween(1,100);C1 This expression creates channel C0 with values aligned to the same fiducials as C1. |
If the output channel does not already exist, and the expression doesn’t reference another channel with required attributes (start fiducial, increment, data type), you’ll be prompted to specify a master channel from which to extract these details.
