Surfaces Tab
The Surfaces tab tab provides access to surface operations and is only available when using the Voxel Math tool.
Each tab item includes a tooltip that shows the required arguments and a brief description of the function.
Statistics Operators
Button |
Syntax |
Definition |
.intersect |
Returns true (1) if voxel cells intersect a surface or grid; otherwise false (0). |
.inside |
Returns true (1) if voxel cell centers are inside a closed surface; otherwise false (0) . |
.side |
Determines the relative position of voxel cell centers to an open surface or grid:
The outcome is set to DUMMY if the side cannot be determined. For those voxel cells that do not lie inside the volume normal to the finite surface and bound by the edges of the surface, the surface cannot be determined. |
.dist |
Returns the closest distance of voxel cell centers to a surface or grid, along the normal to the surface. |
.insidedist |
Returns the signed closest distance of voxel cell centers to a closed surface:
.sidedist |
Returns the signed closest distance of voxel cell centers to an open surface or grid.
