Seequent Evo Settings
Access the Seequent Evo Settings dialog from the Seequent Evo menu (in the top-right corner of the menu bar) to select a Seequent Evo instance and connect to its available workspaces. Once connected, you can import geoscience data from available workspaces and publish geoscience data from your current project to any available workspace within the selected instance.
After closing the dialog, hover over the Seequent Evo menu icon to view the name of the connected instance.
This option is unavailable if you are not signed in with your Bentley account or if your subscription does not include Seequent Evo entitlements. For more details, see Oasis montaj Integration with Seequent Evo
Seequent Evo Settings - dialog options
The dialog displays the available instances within your Seequent Evo organization(s), along with the workspaces to which you have access.
Select an Instance
Filter your selection by organization, instance name, or connection state:
Filter By:
The list contains all instances within your Seequent Evo organization(s), sorted in alphanumeric order. You can filter the selection by:
  • Name: Keep the default selection to filter by instance name.
  • Organization: Select this option to filter instances by organization.
  • Status: Select this option to filter instances based on their state (online or offline). Offline instances are greyed out in the list.
Search
Enter a keyword or search term based on the selected filter. The list updates dynamically as you type. Changing the Filter By option dynamically refreshes the results based on your search term.
Select instance
Click an instance to highlight and select it.
View Workspaces in the Selected Instance
A second list appears, displaying your workspaces within the currently selected instance, sorted in alphanumeric order. Workspaces shared by other users within the same instance will also be added to the list.
Click a column header to sort the list in ascending or descending order.
Filter your selection by workspace name, permission level, creation date, or creator name:
Filter By:
Select a filter based on the available parameters:
  • Name: Keep the default selection to filter by workspace name.
  • Your Permission: Filter by your permission level. For details on different workspace permission levels, refer to the Workspace Permissions topic in the Evo help.
  • Created On: Filter workspaces by creation date.
  • Created By: Filter workspaces by the creator name.
Search
[OK]
Click OK to close the dialog and connect to the selected instance.
Hovering over the Seequent Evo icon (in the top-right corner of the menu bar) will confirm that you are connected to it.
Once connected, you can Import from Seequent Evo and Publish to Seequent Evo within the workspaces of the selected instance.
Your selection will be retained when reopening the dialog within the same project.
Creating a Workspace in Seequent Evo:
If no workspaces are available in the selected instance:
  • Close the Seequent Evo Settings dialog.
  • Click the Seequent Evo menu again.
  • Select Go to Seequent Evo to open the Seequent Evo portal in your web browser.
    If you're not signed in, the evo.seequent.com/login page will open. Click the [LOGIN] button in the top-right corner and sign in with your Bentley account.
  • Once signed in, create a workspace within the current instance.
To learn more about Seequent Evo workspaces—including how to create your own and invite team members—refer to the Evo help topics: Creating a Workspace and Managing Workspaces.
